Reatta Owners Journal
To troubleshoot the ABS system you may need to check the codes stored in the EBCM. You must short two pins on the ALDL connector located under the dash on the drivers side. How To Check ABS Codes
Checking ABS codes cannot be done with code scanner or through the Reatta diagnostics screen.
